Hi! How loud is this motor? I can't find any info on that. Are there any videos showing sample operation?
userHead JaneYu 2016-05-06 03:37:11 7 Views5 Replies
2016-08-29 12:51:54
Can you confirm this blocking torque and stall current? It seems the torque is too high and the stall current is too low to be true.
Thanks.
2016-06-21 05:48:07
I dont have any oscilloscope but I would like to know how output waveform of encoder looks and how I can use output of encoder to setting position of output shaft of gear.
2016-05-08 20:38:08
which is recomended PWM frequency ?
Stall current ?
Free-run current @159rpm ?
Is it possible to have different gear ratio ?
2016-05-08 07:54:33
Which is recomended PWM frequency ?
Stall current ?
2016-05-06 18:12:17
A little noisy, just like a normal motor, but the connection is very convenient.
