Does WiFi in LattePanda work without external antenna?
JaneYu 2016-09-06 20:27:01 5 Views5 Replies Does WiFi in LattePanda work without external antenna?
I can't imagine this not working reasonably well for anything at 2.4GHz that uses a u.fl connector. There would have to be the kind of active circuitry that wouldn't exist in a $5 antenna, or any really. Personally I use an antenna from an old router along with a u.fl to reverse SMA patch cable.
The new Latte Panda Alpha seems to use a smaller connector so I hope they make one of these with that smaller connector.
JaneYu The answer is no, the cases do not come with a place to attach the antenna, which is large compared to the LP at the stated length of 6.7 inches. If you have a dremel and skill, you could drill a hole either above the display connector or above the Micro SD slot area and connect it that way.
JaneYu
