Is it possible to create a Digital Temperature & humidity sensor (With Stainless Steel Probe) with the SHT3x sensor instead of the SHT1x?
userHead JaneYu 2016-09-10 18:51:22 5 Views19 Replies
2023-08-30 15:28:29
Could you run the I2C scanner for ESP32 to see if the ESP32 can scan the I2C address of the SEN0148 normally?
I2C scanner for ESP32:
https://github.com/YeezB/ES...
And please send your test video to
[email protected]
We will review your question as soon as possible
2023-08-30 01:29:55
I cannot get it to work with my ESP32.
2023-05-10 04:36:41
Does this sensor work with Xilinx FPGA with level translators? i.e. If I change the I2C voltage levels to fit with the FPGA signal level, will the communication work?
The operating voltage of the sensor is 5V.
You can refer to our library documentation: https://github.com/DFRobot/...
You need to modify the FPGA control commands according to the library file.
2023-05-10 17:40:55
2022-03-10 09:40:24
The sensor uses the IIC communication method. Due to the firmware update, the current version uses the SHT3X sensor, and the wiki has been updated synchronously.
2021-11-04 06:46:31
Hello, can you confirm the wiring and code you used? Some pages show this has a SHT1X, some show SHT20, none of the suggested wiring or sample code has worked for me.
2018-12-04 04:27:11
Could you tell how many sensors would I need for a greenhouse 20mx20m?
2018-04-12 23:54:15
Hello Is this sensor suitable for soil humidity purpouses?
2018-01-26 05:33:09
Greetings, I want to know if there is a way to connect this sensor, STH1x, with a PLC Siemens S7-1200, because i see you have a special library for Arduino controllers.
2017-08-21 12:37:21
You can inquire the minimum amount, discount from our store Email, which is [email protected]
2017-08-18 11:52:50
Can you give me an example? Do you sell?
i'm sorry we can't do that, it's an agent product, customisation is requested a MOQ
2017-08-18 14:06:10
2017-08-17 10:16:08
Hello, is it possible to extend the wire to 10 meter?
2017-02-28 07:38:41
Would the humidity portion sensor & probe work in a high temperature (300 C) environment? I realize that's outside the temperature range, but I don't care about the temperature.
2017-02-09 15:01:54
No, but I think it is not difficult. Just google "SHT10 beaglebone" or "SHT10 raspberry"
2017-02-09 15:00:18
Yes, it could be used as soil moisture sensor
2017-02-04 04:33:58
How long is the cable of this sensor?
2016-12-02 14:31:08
Can I connect this directly to the lattepanda? Or do I need an other board in between?
Yes. I think so. What you need to do is just plug in the sensor pin to the Arduino pinout on LattePanda. And program the LattePanda onboard Arduino to get the sensor data.
Since LattePanda integrates an Arduino Leonardo, technically, it works with all Arduino compatible sensors.
2016-12-02 14:34:30
