How does this shield connect to the Arduino Mega
userHead JaneYu 2016-11-01 04:53:30 10 Views4 Replies
2017-01-18 20:31:38
Sorry for the late. You could contact [email protected] and we will help you deal with this hardware problem. It'll be a great help if you could illustrate the two pins in the product picture. Looking forward to your reply.
2016-12-19 18:09:02
Arduino TX to Xbee Din? According to the schematic, S1 should be xbee/USB switch
2016-11-01 04:55:04
Sorry, how does the xbee shield connect to the Arduino MEGA 2650
Hi, it is same. you can plug it on the mega board directly,and xbee will communicate with Serial. if you need other serial port, you can check this shield https://www.dfrobot.com/ind...
2016-11-01 12:17:14
