I have placed the shield (LCD screen) onto the Arduino DUE.I downloaded the correct Libraries and got the Sketch from the WIKI page.Nothing is happening to the LCD (looks like no p...
JaneYu 2017-06-02 01:56:13 10 Views7 Replies I have placed the shield (LCD screen) onto the Arduino DUE.
Nothing is happening to the LCD (looks like no power) ... please help
I also connected the Arduino DUE to a power supply of 10V and 1 AMP ... but the screen still doesn't light up.
The "lcd.println();" doesn't work as intended in my code. Each line is printed on top of each other.
Could it have something to do with these warnings that appear when I compile the code:
warning: '__progmem__' attribute ignored [-Wattributes]
virtual void draw(const PROGMEM byte* buffer, uint16_t width, uint16_t height) {}
Thanks!
JaneYu the display is not functioning , I charge the examples of software on the wiki and with the command println only appears the first character of the string of characters.
I am using DFRobot_TELEMATICS_3.5-_TFT_Touch_LCD_Shield- with the Arduino Mega 2560
My code is as follows:
#include <arduino.h>
#include <spi.h>
#include <multilcd.h>
LCD_R61581 lcd;
void setup(){
lcd.begin();
lcd.setFontSize(FONT_SIZE_MEDIUM); //set font size
lcd.setColor(RGB16_YELLOW); //set strings color
lcd.setCursor(0, 0);
lcd.print("SAMPLE");
void loop(){
JaneYu I need to run this display by I2C. I am looking for the libraries.
JaneYu There is an I2C library in the related library file https://github.com/Arduinol...
