Hi, can the analog Infra red sensor work through the digital 5A relay to control a Solenoid valve?
JaneYu 2018-02-08 17:51:05 12 Views11 Replies Hi, can the analog Infra red sensor work through the digital 5A relay to control a Solenoid valve?
Well, rotating the potentiometer to change the distance of the sensor, what else do you need to know ?
JaneYu the sensor wotks perfectly on aurdino - but for the sme logic in c its not ! the problem is that the gpio pin wont turn on ...
why is that hepning ? what can i do to detect it right ?
JaneYu How can i adjust the distance range? i want to detect proximity of 15 cm but it is set on 30 cm, How can i change that?
JaneYu Hi,
There is a potentiometer on the top of sensor. https://uploads.disquscdn.c...
Can this work with 3.3V?
JaneYu No, the working voltage is 5V.
You can use ultrasonic sensor which is not harm to human eyes. https://www.dfrobot.com/sea...
JaneYu It should work, it's just a digital sensor that give high or low level signal.
JaneYu
