Is this a dream? or did i just find a non official dsi screen? exactly what i needed for my project))
JaneYu 2019-01-23 06:45:30 38 Views67 Replies Is this a dream? or did i just find a non official dsi screen? exactly what i needed for my project))
Hi, i've bought this display this week, but when i try to connect it with the ribbon cabble I only get short flash when i turn the raspberry on.
JaneYu Hello,
I would like to connect the screen (5") and touch pad over LVDS cable.
I do not need MIPI / DSI connection.
Which controller do you recommend?
Many thanks in advance!
JaneYu Sorry, there is no more V1.0 screen in our warehouse.
May I ask if you are facing some problem on the V3.0 screen?
JaneYu Where can I get details for MIPI-DSI settings for DFR0550, we would like to use it with a different MCU.
(i.e. Timing like Backporch, Sync width and height in pixels and lines, etc.)
Paul
JaneYu We have the schematic and layout at the bottom the wiki.
You could check this website:
https://dfimg.dfrobot.com/n...
The touch screen feature continues to be an issue. This really needs a resolution. Having not really thoroughly tested this (my fault), my customers are now complaining this feature does not work properly. This is with a Raspberry Pi 4B running Buster. Currently I need to set the touch screen feature off in config.txt.
JaneYu I just bought 3 of these to use on some RPI 3B+'s via DSI, the screen works, but the wifi stops working. As soon as I disconnect the screen, the wifi works. Do I have to enable something?
JaneYu I have the same issue on raspberry os. Seems to be some OS issue. Any solution for this?
JaneYu Hello,
The 5" Raspberry PI display (SKU: DFR0550) is out of stock again. When you anticipate these being available again?
JaneYu Hi. Have this card up and running on my Raspberry Pi 3B+ but I can't use gestures (multi-touch) e.g. to scroll up-down on webpage.
I have Raspberry Os Lite with minimal gui installed (xserver-xorg, x11-xserver-utils, xinit, openbox and chromium-browser).
Should it work out of the box? How to solve?
JaneYu Hi Antonio,
Thanks for reaching out.
I have used this recently with Rpi4. I did not find any issues with the touchscreen.
JaneYu For my application/**, I would need a longer FFC cable than the supplied 45 mm. How long can the cable be and still work?
JaneYu Have you already solved the issue with the DSI interface of Raspberry Pi 4?
JaneYu Hi, Can you show me thick dimension of this screen which only includes mounting nut and the screen?
JaneYu Hi, Can you show me thick dimension of the screen which only includes mounting nuts and screen? Thanks
JaneYu Hi, The backlight can I control by code or just control by potentiometer?
JaneYu
