Hi. May i ask what is the distance between the mounting holes? Is it 17mm?
JaneYu 2023-05-17 15:48:13 10 Views3 Replies Hi. May i ask what is the distance between the mounting holes? Is it 17mm?
2020-03-09 10:52:30
JaneYu
Hi, there is a drawing of the motor, and for others, I advice you could measure basing on the Physical map.
JaneYu 2019-03-18 19:26:14
JaneYu
The encoders will be inevitable nosiy...
There will be similar demands we will sort out, there should be optimization in the next version.
JaneYu 2019-03-18 13:42:16
JaneYu
The motor for devastator is this one:https://www.dfrobot.com/pro..., this motor may not compatible.
JaneYu
