Can it be used as HC06 and send the serial data?
userHead JaneYu 2021-05-03 13:01:28 97 Views9 Replies
2023-12-23 18:13:40
For BLE Pass-through, can I have my phone connected to the module via Bluetooth and the module passing the audio to a Bluetooth speaker?
2023-11-29 17:08:09
How many is the resolution of ADC and DAC?
This module has the 16-bit DAC.
2023-11-30 09:43:56
2023-07-23 03:14:42
Hi everyone,
I'm using a DFR0781 Bluetooth module for one of my audio projects. It's a nice module, but I faced to one issue while developing my project.
I use a special custom APP with BLE connection that needs a special UUID(128bit).
Definitely this module has FFF0(16bit) as the service UUID.
Generally this 16‑bit UUID users can set it by themselves.
But If I need a special 128bit UUID, I need to contact Qingyue Electronics to customize and modify the underlying settings of the module.
Could you please tell me how to contact them?
Thanks!
2023-03-03 03:04:23
What is the name of the Bluetooth when you wnat to connect with your mobile phone
2022-03-07 21:44:20
Is there a ROHS certificate and a Bluetooth SIG compliance certificate availalbe for this device?
We currently do not have the corresponding certification, only the BQB certificate of the chip
2022-03-09 11:15:24
2021-10-21 02:47:57
Hi, can the Audio & BLE/SPP Pass-through Module - Bluetooth 5.0 (BT401) be setup in source mode instead of sink and how.
Eric
2021-09-26 16:45:00
Hello, can i put earphone in bluetooth module for listen the sound of my phone at the same time that the module receive serial data ?
