RS485 MODBUS-RTU Soil NPK Measure Sensor
Hatarok 2025-06-12 03:56:52 2049 Views1 Replies Hello all,
The RS485 MODBUS-RTU Soil NPK Measure Sensor from DFRobot was purchased. I would appreciate tips to get readings from this sensor.
I want to use the Serial Monitor on Arduino IDE to display NPK values. I am using a MAX 485 modbus and Arduino Nano.
The documentation for data formatting for the NPK sensor is here:
https://wiki.dfrobot.com/RS485_Soil_Sensor_N_P_K_SKU_SEN0605
Currently, powering the sensor with 5 V on the Arduino Nano, and I have tried using a 9 V battery in addition, but no luck getting values.
The sensor is in some outdoor soil but getting 0's for all readings with the current code below:
#include <ModbusMaster.h>
#include <SoftwareSerial.h>
SoftwareSerial rs485Serial(2, 3); // RX, TX
ModbusMaster node;
// RS485 Direction Control
#define MAX485_DE 7
#define MAX485_RE 8
void preTransmission() {
digitalWrite(MAX485_RE, HIGH);
digitalWrite(MAX485_DE, HIGH);
void postTransmission() {
digitalWrite(MAX485_RE, LOW);
digitalWrite(MAX485_DE, LOW);
Serial.begin(9600);
rs485Serial.begin(9600);
pinMode(MAX485_RE, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
node.begin(1, rs485Serial);
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
Serial.println("NPK Sensor Initialized via RS485");
uint8_t result;
result = node.readInputRegisters(0x00, 3);
if (result == node.ku8MBSuccess) {
Serial.print("Nitrogen (N): ");
Serial.println(node.getResponseBuffer(0));
Serial.print("Phosphorus (P): ");
Serial.println(node.getResponseBuffer(1));
Serial.print("Potassium (K): ");
Serial.println(node.getResponseBuffer(2));
} else {
Serial.print("Read error. Code: ");
Serial.println(result);
delay(2000);
Try indoors with the sensor in damp soil, not bone-dry dirt.
Use a USB to RS-485 adapter and a PC tool like Modbus Poll to test if needed.
Add a Modbus termination resistor (like 120 ohms) between A and B if communication is unreliable.
ahsrab.rifat
