Two Bluno/ BLE devices cannot communicate properly?
JaneYu 2024-07-11 15:17:24 585 Views0 Replies Two Bluno/ BLE devices cannot communicate properly?
2025-07-24 15:03:37
JaneYu
Common suggestions for communication problem:
1. Update the firmware to the latest version;
2. Apply the default setting by AT command AT+SETTING=DEFAULT;
3. Check if the serial port is used correctly if you use Leonardo, Mega etc which contains multiple serial ports. e.g. Leonardo uses Serial1.****() instead of Serial.****() for the I/O Pin 0,1. The Serial.****()is for the USB port.
Check if the baud rate in different places are corresponding: (38400 is suggested for 8MHz boards)
4. In codes > Serial*.begin(?)
BLE modules > Baud rate setting
5. Reboot the module.
JaneYu
