Default password is often '0000' or '1234' - ensure Bluno's BLE is discoverable.
userHead JaneYu 2024-07-11 12:03:07 688 Views0 Replies
Why I can not connect Bluno by my iPhone/ Android phone(5.1 version)? I am sure they suppot BLE devices(syetem version & BLE module). And it required a password, what's the password?
2025-07-24 15:03:54
1. Please connect Bluno using the App developed by DFRobot like the one above called Bluno Basic Demo, it requires no password. If you have hit the Bluno through Setting Panel, and connected(or not), please hit on it again to remove (forget) this device from your phone, and then use the app to search and connect.
2. The password was for the HID connection, actually once you set HID mode, it requires no password or PIN. surely HID mode should be previously set by AT+FSM=FSM_HID_USB_COM_BLE_AT.
3. By the way, you should notice that other Apps for BLE talk might NOT compatible. If you need to develope your own App, you can customize the BlunoBasicDemo which is open source. Link.
