Possible reasons for no output or output errors
JaneYu 2024-07-11 23:46:19 2888 Views0 Replies Possible reasons for no output or output errors
2025-07-24 15:24:15
JaneYu
1. The computer has a COM port, but the selected port is incorrect.
2. TTL to 485 module operation/programming toggle switch selection is incorrect.
3. Wrong baud rate.
4. The 485 bus is disconnected, or the A and B lines are connected reversely.
5. If there are too many devices or the wiring is too long, power supply should be provided nearby.
Equipment damage.
JaneYu
