Why sometimes the acquired data range exceeds the measuring range?
userHead JaneYu 2024-07-11 00:16:47 540 Views0 Replies
2024-07-11 00:16:47 There is a limitation on the measurement range of BMM350, i.e., the sum of absolute values for each axis should be less than this value. That is, SQRT(Hx^2 + Hy^2 + Hz^2) = 2000uT You can refer to subsection 5.3 of the BMM350 datasheet Below. userHeadPic JaneYu
