Improving low-reflectivity detection (diffuse surfaces) with the SEN0158
Peter.Love 2025-11-06 21:36:41 375 Views6 Replies Hi all,
I’m working on a project using the SEN0158 IR positioning camera and am running into difficulties detecting laser reflections from diffuse (low-reflectivity) surfaces at a distance of ~2-3 m. I’d love to hear about any techniques you’ve used, or experiments you’ve run, to improve detection in such conditions.
Does anyone know for sure whether the SEN0158 allows manual adjustment of analog gain or exposure via register writes? I couldn’t locate documentation beyond the basic I2C interface in the wiki.
Thanks in advance,
I totally relate to the challenges of low-reflectivity detection! I once struggled with a project using similar sensors and spent hours recalibrating. It’s all about those angles!
Geometry Dash
Marvin.Meyers Thanks for sharing.
<a href="https://myinfo-kroger.xyz/">myinfo kroger</a>
micheal.james Hi! Detecting laser reflections from low-reflectivity surfaces at 2 3 meters with the SEN0158 can be tricky. Increasing IR illumination, using optical filters to block ambient light, and applying frame averaging in software can help improve detection.
As for manual gain or exposure, the SEN0158 doesn’t publicly expose analog gain/exposure registers via I2C, so most adjustments are done through the API or software settings. For hardware-level control, contacting the manufacturer may be necessary.
myinfo kroger
micheal.james I completely understand the challenges with detecting reflections from low-reflectivity surfaces. In my experience, adjusting the gain can significantly enhance detection. It’s a good idea to explore any firmware updates or community-driven modifications that might provide more functionality. By the way, if you’re looking for some engaging projects to boost your skills, check out Block Blast; it might inspire new ideas for your work!
<a href="https://blockblasts.io/">Block Blast</a>
[url=https://blockblasts.io/]Block Blast[/url]
[Block Blast](https://blockblasts.io/)
: Block Blast.
Lincoln.Wynne I completely understand the challenges with detecting reflections from low-reflectivity surfaces. In my experience, adjusting the gain can significantly enhance detection. It’s a good idea to explore any firmware updates or community-driven modifications that might provide more functionality. By the way, if you’re looking for some engaging projects to boost your skills, check out [url=https://blockblasts.io/]Block Blast[/url]; it might inspire new ideas for your work!
Lincoln.Wynne The SEN0158 is the DFRobot “Gravity IR Positioning Camera” (the same family as the Nintendo Wiimote IR camera). Its public docs only show the simple I²C init and the 4-blob output, but community reverse-engineering and academic work show you can change deeper sensitivity settings by writing additional registers during initialization.
ahsrab.rifat
