LBH6510S Fan Replacement for LattePanda Sigma — Sleeve Bearing Failure in Continuous Operation
Hauke 2026-03-06 16:38:52 754 Views4 Replies Hi all,
we are having issues with fans on multiple LattePanda Sigmas in a continuous operation environment.
Similar problems have been discussed here, but has there been a definitive solution? The fan seems to struggle on startup — it attempts to spin up, detects an issue, retries, and eventually runs quietly. This points to a sleeve bearing failure, which is expected to worsen over time.
The easiest fix would be a direct replacement, but I can't find the Li Da Motor LBH6510S available as a retail product anywhere.
Does anyone know of a compatible drop-in replacement (same dimensions, 12V, 4-wire PWM, 1.27mm pitch connector)?Has anyone successfully swapped in a dual ball bearing alternative for better longevity?Or is there a way to source the LBH6510S separately?
Thanks in advance!
2026-05-22 23:56:51
chatwin.lansdowne
I have the same problem. I have a bunch of these computers, if the fans are going to be failing about 1 year in, I'd like to have spares on hand.
chatwin.lansdowne
