SEN0440 (MiCS-5524) Confusing Gas Detection Specs and No I2C Interface? Need Clarification
userHead syhfsfsa 2026-05-23 06:05:47 619 Views1 Replies
Hi everyone,
I’m planning to use the SEN0440 (MiCS-5524) gas sensor in my project, but after reading the wiki and sample code, I found several confusing points and hope someone with real experience can clarify them.
The wiki mentions an I2C interface, but the hardware image only shows Analog Value and Enable pins. Does this module actually support I2C communication, or is it analog output only?Is it possible to get separate PPM/PPB values for gases like CO, CH4, NH3, H2, H2S, etc., individually? Or does the sensor only provide a mixed gas response?The documentation seems inconsistent. Some sections mention 8 detectable gases, others mention 5 or 6. How many gases can this sensor realistically identify or measure individually in practical use?
From what I understand so far, it looks more like a general air quality / combustible gas sensor rather than a true multi-gas analyzer, but I’d love to hear feedback from people who have actually used it in real projects.
Thanks!
geometry dash meltdown
2026-06-01 16:57:31
Thanks for pointing this out. The documentation is confusing here, and we’ll update it to make the SEN0440 behavior clearer.
For the SEN0440 MiCS-5524 breakout, please treat it as an analog-output sensor, not an I2C sensor. This board exposes 5V, GND, A0, and EN; A0 is the analog output and EN is the enable pin.
It also should not be used as a true multi-gas analyzer. MiCS-5524 has cross-sensitivity, so it can respond to several gases, but one analog signal cannot separately identify CO, CH4, NH3, H2, H2S, etc. in a mixed environment.
In practice, it is better suited for rough gas presence, leakage, or air-quality trend detection. The PPM calculation in the library is only an estimate for a selected gas curve under controlled or known-gas conditions.
userHeadPic Yx
