SEN0366 infared laser distance sensor stops working after pulsing 4 times
aas1as 2026-05-23 06:06:36 5 Views0 Replies
I recently got a SEN0366 infared laser distance sensor that was initially working well with a continuous laser beam, however it now pulses four times then waits several seconds before repeating. This occurs when the laser is simply plugged into the computer via usb. How may I fix this issue?
