Why does the output stay HIGH or LOW when the sensor is not moving?
userHead Cyn 2026-06-18 16:42:39 570 Views1 Replies
2026-06-18 16:46:57
The digital output may vary depending on sensor orientation, wiring, and trigger state. Check the wiring, test the module with a simple digital read program, and gently tap or shake the sensor to confirm whether the output changes.
userHeadPic Cyn
