How Often Should You Test Your Smoke Alarm?
safe-tech 2026-10-31 15:57:58 11 Views0 Replies Testing smoke alarms regularly is an important part of home fire safety. Follow the manufacturer's instructions and use the test button to check that the alarm is working correctly. You should also keep alarms free from dust and replace units according to their service life.
