Digital RGB LED Weatherproof Strip 60 LED - (1m)
$23.05
SKU: FIT0356
The LED strip features integrated RGB control, signal reshaping, and weatherproof design. It offers 256 color brightness levels, suitable for various decorative applications.
Purchase this product and earn 125 reward points, which are tied to VIP membership program. Learn More >
Digital RGB LED Weatherproof Strip 60 LED (1m) delivers vibrant programmable lighting using individually addressable WS2812 LEDs arranged at 60 pixels per meter. Each LED integrates an RGB emitter and control circuit inside a compact 5050 package, enabling precise color and brightness control through a single‑wire digital signal. This addressable lighting strip supports dynamic animations, color gradients, and responsive visual effects for creative electronics and interactive installations. Compatibility with common controllers such as Arduino, ESP32, and micro:bit allows seamless integration into DIY electronics, IoT lighting systems, and programmable decoration projects.
Individually Addressable RGB Lighting
This programmable LED strip features WS2812 integrated driver LEDs, enabling independent control of every pixel along the strip. Each RGB node can display 256 brightness levels per color channel, producing up to 16,777,216 color combinations. Such granular control enables smooth gradients, animated lighting sequences, reactive music visualizers, and complex lighting effects commonly used in maker installations, stage decorations, and creative electronics projects.
Integrated Control and Signal Conditioning
Every LED package combines the RGB emitter with an internal control IC, digital data latch, and signal reshaping amplifier. This architecture ensures stable signal transmission across cascaded LEDs even over longer chains. Built‑in oscillator timing and programmable constant‑current control maintain consistent brightness and color accuracy across the entire strip, supporting high refresh rates and reliable operation for dynamic lighting displays.
Low Power, Durable, and Weatherproof Design
The flexible lighting strip operates from a low‑voltage supply while delivering high brightness and long operational lifespan exceeding 50,000 hours. A weather‑resistant protective coating enables deployment in decorative indoor setups as well as protected outdoor environments. This flexible digital lighting solution suits creative installations, wearable electronics, architectural accents, and artistic displays requiring programmable illumination.
Figure: Smallest wireless NeoPixel driver using ESP8266 module
Figure: Programmable fiber optic fairy wings lighting effect
Creative projects built around this programmable RGB lighting strip include interactive music visualizers, decorative fairy wings, programmable writing boards, and motion‑activated holiday decorations. Example tutorials include How to Make Music IQ Led Lights with arduino board?, How to make a Programmable Fiber Optic Fairy Wings?, LED writing board (micro:bit compatible), How To Make A Micro:bit Heart Rate Monitor, and How to Make an Automatic Christmas Tree, demonstrating interactive lighting effects for creative electronics and STEM learning.
  • Integrated control circuit and RGB chip
  • Built-in signal reshaping circuit
  • Built-in electric reset circuit and power lost reset circuit
  • Each pixel of the three primary color can achieve 256 brightness display,16777216 full color display,scan frequency no less than 400Hz/s
  • Cascading port transmission signal by single line
  • Data speed: 800Kbps
  • Over 50,000 hours life
  • KTV/Nightclub/Hotel Wall
  • Outdoor signs/banners
  • Home decorative lighting
  • Cars
  • Lighting signals
  • 60 RGB LEDs
  • Power supply: 5V@1A (can work from 3.3V to 5V)
  • For this strip you need 5V/1A at least as it is 1M long: if current was not enough, the color may not be correct.
  • IC name: WS2812
  • Brightness Grade: 256
  • Weatherproof
  • Note:LEDs can work from 3.3V-5V but the luminance will be different
  • Digital RGB LED Weatherproof Strip 60 LED - (1m) x1
Blog Programmable Fiber Optic Fairy Wings
Nov 07, 2016
Weather Lamp
Projects Weather Lamp
Mukesh Sankhla
Nov 14, 2022
Only 15 Left
