Solar Lipo Charger (3.7V)
$4.90
SKU: DFR0264
  • $4.80 2+ items
  • $4.60 5+ items
  • $4.40 10+ items
Solar charger for 3.7V lithium battery with 500mA max current, reverse polarity protection, and charging indicators. Ideal for green energy projects.
This Solar lipo charger is designed for single Lithium battery (3.7V) for intelligent charging, with input reverse polarity protection. The maximum charging current is 500 milliamperes and the connection is simple and convenient. Used with the solar battery and lithium battery, you can quickly build a solar power system. Nowadays green power, for stationary or mobile projects is becoming highly requested.
Add this to your project with solar panels and make a stand alone embedded application fast. Add some of our best choices of wireless and data stream your sensor or monitor devices.
  • Simple solar charger.
  • Solar power system, Green energy.
  • Input Voltage: 4.4 ~ 6V
  • Charging Current: 500mA Max (Depending on the solar battery supply capability)
  • Charging Cutoff Voltage: 4.2V
  • Operating Temperature: -40 ~ 85℃
  • Module Size: 33mm * 33mm * 12mm(1.30"*1.30"*0.47")
  • Requisite battery: 3.7V lithium battery (Please note the maximum permissible charging current of the lithium battery)
  • Charging Indicator:
            No Battery:  Red LED Flashing
                Charging:  Red LED
                Done:    Green LED
Optional Parts
  • Solar Charger Module   ×1
Ziad.Naesah Dec 13, 2025
The Solar LiPo Charger is a solid choice for hobbyists and developers working on solar-powered, battery-based projects. While it’s not designed for fast or high-current charging, it delivers safe, reliable performance for low-power applications.
Mattia. Aug 07, 2023
All ok, the description write in a good way.
