Gravity: Digital Adjustable Infrared Proximity Sensor (10~80cm)
$6.90
SKU: SEN0019
  • $6.60 2+ items
  • $6.20 5+ items
  • $5.80 10+ items
An infrared distance sensor with adjustable range from 10cm to 80cm. Ideal for robotics and indoor projects, it features easy assembly and low cost.
This is an Arduino infrared distance sensor. It has an adjustable detection range, 10cm - 80cm.  It is small, easy to use, assemble, and inexpensive.
Useful for robotics, interactive media, industrial assembly line, etc. Infrared wave length is part of the Sun's natural light spectrum. While is a nice fit for indoor projects, outdoors with plenty of sun light and reflective surfaces on it's sight is not adviced. It's incredibly repurposable and can be used for a lot of different projects. The adjustable screw on it's back makes it very convenient for different purposes. After digital read shows on your Arduino pin and then you are ready to go. It is a great sensor choice for quick prototyping.
Use it on a robot for wall detection and wall follower, or as some of the projects listed below as a trigger system. It's round shape with the screwable holders make it a good choice for a home made assembled robot, with a hole of it's diameter and the holders you can place it aiming at different positions on a robot. Or even place it near your PC to turn on and off your monitor.
To ease the difficulty,  a Gravity Interface is adapted to allow plug&play.  The IO expansion shield is the best match for this sound senor connecting to your Arduino.
  • Power supply: 5V
  • Current: 100mA
  • Recommended working distance: 10~80cm
  • Minimum working distance: 3cm (when the detected surface is a non-reflective black plane)
  • Maximum working distance: 90cm (when the detected surface is a flat reflective white plane)
  • Brown: +5V; Black: Signal; Blue: GND
  • Dimension: 45 x 18 x 18 mm (1.8 x 0.7 x0.7 in)
  • Gravity: Digital Adjustable Infrared Proximity Sensor (10~80cm) x1
    How Accurate are mmWave Sensors?
    Blog How Accurate are mmWave Sensors?
    May 04, 2023
    Tom.Kvichak Jul 13, 2022
    This proximity sensor has a greater range than most sensors used in Arduino projects. Easy to mount on the facia to sense motion to activate a sequence of events.
