FPV Nylon Pan & Tilt Kit (Without Servo)
$3.90
SKU: FIT0415
  • $3.80 2+ items
  • $3.60 5+ items
  • $3.40 10+ items
Versatile FPV nylon Pan and Tilt allows mounting cameras or modules on robots and drones. Compatible with 9~12g servos, requires separate purchase.
Add a camera, a laser beam emitter, or even a remote cannon on your robots and drones! This is a useful FPV nylon Pan and Tilt for multiple uses. It is compatible with most 9~12g small servos. With this holder, you could easily mount camera or many other small modules on on the servo. The only limit? Your imagination.
Note: This product doesn't contain servos. Please choose the servos separately.
Compatibility:9g micro servo (1.6kg)(SER0006
Project 1: Microbit Projects: Yes/No Bear
There are 2 possible answers. Either yes or no. We randomly generate the outcome when a button is pressed. When the answer is yes, the display will show Y & the tilt servo will response. When no, the display will show N and pan servo will response.
Part needed
2 x 9G servo motor
1 x microbit
1 x micro:mate(breakout board)
1 x Pan tilt kit
1 x stuffed toy bear
  • Height:65mm (2.56")
  • Weight:20g
  • FPV Nylon Pan and Tilt (Without Servos) x1
  • Screw package x1
