SRF08 Ultrasonic Distance Sensor (3~600cm)
$49.00
SKU: SEN0007
Ultrasonic sensor with 6m range, low power use, built-in echo timing, and light sensor. Connects via I2C. Measures distance in uS, mm, or inches.
Purchase this product and earn 490 reward points, which are tied to VIP membership program. Learn More >
SRF08 Ultrasonic Sensor represents an upgraded ultrasonic ranging solution designed for accurate distance measurement in embedded electronics and robotics. Compared with earlier ultrasonic modules, this long‑range distance measurement unit delivers extended detection capability up to 6 meters while maintaining efficient power consumption. The compact sonar-based sensing board integrates internal echo timing and communicates through a standard I2C interface widely supported by development platforms such as Arduino and Raspberry Pi. With built‑in light sensing and adjustable gain control, this ultrasonic detection module enables reliable environmental awareness for autonomous systems, smart devices, and experimental electronics.
Extended Detection Range with Efficient Power Use
This ultrasonic ranging module provides reliable distance measurement from 3 cm up to 6 m using a 40 kHz acoustic signal. Optimized internal electronics reduce energy consumption compared with earlier designs, requiring only 15 mA typical operating current and approximately 3 mA in standby mode. Such efficiency makes the distance sensing board suitable for battery-powered robotics and embedded controllers. The long measurement range combined with stable acoustic performance enables accurate obstacle detection, spatial monitoring, and proximity measurement in indoor automation and mobile robot navigation.
I2C Interface with Intelligent Echo Processing
This ultrasonic measurement board communicates through a standard I2C bus, allowing straightforward integration with a wide variety of microcontroller platforms and embedded computing systems. Internal timing hardware automatically processes transmitted pulses and returning echoes, eliminating complex timing calculations from the host controller. Multi‑echo capability allows the sensor to continue scanning after the first detected reflection, increasing reliability in environments containing multiple objects or uneven surfaces. Such intelligent signal processing simplifies firmware development while improving measurement stability.
Integrated Light Sensing and Adjustable Signal Gain
A front‑facing light sensor expands sensing capability beyond ultrasonic distance measurement by enabling ambient light detection within the same hardware platform. Adjustable analogue gain ranging from 94 to 1025 across 32 programmable steps provides flexibility for tuning detection sensitivity based on environmental conditions. This adaptive signal amplification improves performance in complex acoustic environments where reflections vary in strength. Combining ultrasonic ranging and light monitoring within a compact sensor board enables multifunction environmental sensing for robotics experimentation and smart embedded projects.
Versatile sensing capability allows this ultrasonic distance module to support robotics obstacle avoidance, automated measurement systems, environmental monitoring devices, and interactive electronics. Reliable long‑range detection combined with I2C communication simplifies integration into embedded platforms, enabling engineers and educators to build intelligent systems capable of perceiving both spatial distance and ambient lighting conditions within compact electronic designs.
  • Ultrasonic distance measurement using 40 kHz acoustic frequency
  • Detection range from 3 cm to 6 m
  • Standard I2C communication interface
  • Internal echo timing reduces processing load on host controller
  • Multiple echo detection improves measurement reliability
  • Front-facing integrated light sensor
  • Adjustable analogue gain from 94 to 1025 in 32 steps
  • Compact module suitable for embedded systems and robotics
  • Robotics obstacle avoidance
  • Autonomous navigation systems
  • Distance measurement instruments
  • Environmental sensing platforms
  • Interactive electronics projects
  • Smart automation devices
  • Voltage - 5v only required
  • Current - 15mA Typical. 3mA Standby.
  • Frequency - 40KHz
  • Range - 3cm -6m (1.2-236.2 in).
  • Max Analogue Gain - Variable 94 to 1025 in 32 steps.
  • Connection - Standard I2C Bus.
  • Light Sensor - Front Facing light sensor.
  • Timing - Fully timed echo, freeing host controller of task.
  • Echo - Multiple echo - keeps looking after first echo.
  • Units - Range reported in uS, mm or inches.
  • Small Size - 43mm x 20mm x 17mm (1.7x0.8x0.7 in) height.
  • SRF08 ultrasonic sensor x1
    How To DIY a Robot with Function of Gap Avoidance
    Blog How To DIY a Robot with Function of Gap Avoidance
    Jun 23, 2016
    Only 19 Left
