Gravity: Photoelectric High Accuracy Liquid Level Sensor for Arduino
$6.90
SKU: SEN0205
  • $6.70 2+ items
  • $6.60 5+ items
  • $6.40 10+ items
A photoelectric liquid level sensor with high sensitivity, minimal calibration, and corrosion resistance. It supports Arduino, Raspberry Pi, and Intel platforms.
This is a photoelectric water liquid level sensor that is operates using optical principles. The advantages of this photoelectric water liquid level sensor are good sensitivity and no need for mechanical parts - meaning less calibration! The corrosion resistant probe is easily mounted and can handle high temperature and high pressure.
The arduino liquid sensor is equipped with an interface adapter for compatibility with the DFRobot "Gravity" interface. To ease the difficulty of using this arduino liquid sensor,  a  Gravity Interface is adapted to allow plug&play.  The Arduino IO expansion shield  is the best match for this senor connecting to  Arduino. As this liquid sensor is able to work at 3.3V which makes it compatible with Raspberry Piintel edison, joule and curie.
Gravity: Analog Photoelectric Water / Liquid Level Sensor For Arduino
Connection Diagram
Installation
Note:
Avoid placing the sensor near bright lights or in direct sunlight as these can cause interference.
  • Model: FS-IR02
  • Type: Photoelectric liquid level sensor
  • Operating voltage: 5 VDC
  • Output current: 12 mA
  • Working temperature: - 25 ~ 105 ℃
  • Low level output: < 0.1 V
  • High level output: > 4.6 V
  • Liquid level detection accuracy: ±0.5 mm
  • Material: PC
  • Measuring range: No limit
  • Life: 50,000 hours
  • Dimension: 28 x 28 mm/ 1.1 x 1.1 inches
  • Cable Length: 450mm
  • Weight: 26g
  • Liquid Level Sensor-FS-IR02 probe x1
  • Liquid Level Sensor convert board x1
  • PH2.0-3P Cable
Kyle.Taylor Nov 29, 2025
easy and quick setup
jérémi.darien May 10, 2025
This is an amazing product
Ramsés Ismael. Jul 07, 2020
El producto se ve de calidad. Llegó muy rápido a México y en excelentes condiciones.
