10.1" Diagonal - 1280x800 IPS HDMI/VGA/AV Display (Compatible with Raspberry Pi & LattePanda)
$119.00
SKU: FIT0476
10.1-inch 1280x800 IPS display for mini PCs with HDMI/VGA/AV inputs, requiring 7.5~12V power. Features audio output and is ideal for various creative projects.
Purchase this product and earn 1190 reward points, which are tied to VIP membership program. Learn More >
DFRobot 10.1" 1280×800 IPS Display is a compact high‑resolution monitor designed for maker computers and embedded development platforms. The widescreen WXGA panel delivers sharp visuals and wide viewing angles, making the display suitable for portable computing, robotics interfaces, and multimedia dashboards. Built with HDMI, VGA, and AV inputs, this versatile LCD solution integrates easily with platforms such as LattePanda, Raspberry Pi, and other mini PC systems. The slim IPS screen enables clear output for software development, digital signage, robotics UI panels, and compact workstation builds while maintaining low power consumption and reliable performance.
1280*800 IPS display, Lattepanda accessories, Raspberry Pi accessories
Figure: 10.1 inch 1280×800 IPS display panel
Note: A 7.5~12V DC power adapter is required for operation. A compatible supply can be found here: Wall Adapter Power Supply. Hardware revision V1.1 adds an audio output port.
Wide Compatibility with Embedded Platforms
This IPS display module supports HDMI, VGA, and AV video input, enabling straightforward integration with development boards and compact computers. The multi‑interface LCD panel works smoothly with LattePanda single‑board computers, Raspberry Pi systems, and other mini PC devices used for edge computing or robotics projects. Such flexibility allows the display unit to function as a development monitor, portable workstation screen, or embedded control panel for DIY electronics builds.
High‑Quality 1280×800 IPS Visual Output
The 10.1‑inch WXGA IPS screen delivers a resolution of 1280×800 with a 16:10 aspect ratio, producing sharp images and vivid color reproduction. HFFS display technology ensures wide viewing angles and stable color consistency, while a brightness rating of 350 cd/m² keeps content clearly visible in indoor environments. The hard‑coated surface improves durability for integration into maker projects, kiosk interfaces, or portable computing setups.
Compact Monitor for Creative Projects
This embedded LCD monitor enables interactive visual elements across numerous maker applications. A small robotics display can serve as a robot “face,” while multimedia functions allow the panel to operate as a digital photo frame or compact video display. The thin display assembly and included controller board simplify integration into DIY computing devices, robotics enclosures, and experimental hardware prototypes.
Suitable for embedded computing and creative electronics builds, this compact IPS monitor expands visual capabilities for robotics interfaces, portable development stations, and STEM Education experiments. The flexible display hardware supports applications ranging from mini PC builds to interactive kiosks, giving makers and engineers a practical visual interface for hardware innovation.
  • 10.1 inch IPS LCD panel with 1280×800 WXGA resolution
  • HDMI, VGA, and AV signal inputs for wide device compatibility
  • Designed for embedded computers including LattePanda and Raspberry Pi
  • 350 cd/m² brightness with wide viewing angles
  • Integrated LCD controller board for simple connection
  • Audio output supported (V1.1 hardware revision)
  • Compact and lightweight display suitable for embedded projects
  • Mini PC and portable workstation displays
  • Embedded system monitoring panels
  • Robotics interface or robot “face” display
  • Digital photo frame or multimedia player
  • DIY computing projects and maker prototypes
  • STEM Education development platforms
  • Screen size: 10.1 inch
  • Screen Dimensions: 217 * 135mm/ 8.54 * 5.31 inches (16:10)
  • Display Dimensions: 230 * 149 * 5.0mm/9.05 * 5.86 * 0.2 inches
  • Panel Type: a-Si TFT-LCD Panel
  • Resolution (RGB): 1280x800, WXGA
  • Display Mode: HFFS, Normally Black, Transmissive
  • Surface: Hard coating
  • Brightness: 350 cd/m^2
  • Contrast Ratio: 800:1 (Min.)
  • Input Voltage: 7.5~12V
  • Rated power: 6-7.5W
  • Signal input: AV + VGA + HDMI (HDMI 1.2)
  • Support Audio Output
  • Weight: 358g
  • HDMI+VGA+2AV LCD controller board x1
  • 10.1 inch 1280x800 IPS LCD panel x1
  • Speaker (Pair) x1
  • LVDS Cable x1
  • Keypad Module (Adjustment Button) x1
Raspberry Pi 3B+ Tutorial : Using a 10.1” display
Blog Raspberry Pi 3B+ Tutorial : Using a 10.1” display
Jul 27, 2018
