10.1" Diagonal - 1280x800 IPS HDMI/VGA/AV Display (Compatible with Raspberry Pi & LattePanda)
$119.00
SKU: FIT0476
10.1-inch 1280x800 IPS display for mini PCs with HDMI/VGA/AV inputs, requiring 7.5~12V power. Features audio output and is ideal for various creative projects.
Purchase this product and earn 1190 reward points, which are tied to VIP membership program. Learn More >
This 10.1 inch high-resolution 1280*800 IPS display is specially designed as a monitor for LattePanda(which could be used as windows 10 development board), Raspberry Pi, and other mini PC. The HDMI/VGA/AV interfaces ensure its wide compatibility. Making a digital photo frame, playing a video, adding a face for your robot, you can expand your imagination, make more fun.
1280*800 IPS display, Lattepanda accessories, Raspberry Pi accessories
How to Make a Mini PC / Mini Computer
Note: A 7.5~12V DC power adapter is needed for this monitor. Click Wall Adapter Power Supply to get it. V1.1 increases an audio port.
What is LattePanda?
A LattePanda is a complete Windows 10 single-board computer! It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras, and more. Any peripherals that work on your PC will work on a LattePanda. A LattePanda comes pre-installed with a full, pre-activated version of Windows 10, where you can install powerful tools such as Visual Studio, NodeJS, Java, Processing, and more. Using existing APIs, you can develop your own software and hardware projects on a LattePanda as you would on a normal PC - C#, Javascript, Ruby, and so on. Say goodbye to your bulky laptop!
  • Screen size: 10.1 inch
  • Screen Dimensions: 217 * 135mm/ 8.54 * 5.31 inches (16:10)
  • Display Dimensions: 230 * 149 * 5.0mm/9.05 * 5.86 * 0.2 inches
  • Panel Type: a-Si TFT-LCD Panel
  • Resolution (RGB): 1280x800, WXGA
  • Display Mode: HFFS, Normally Black, Transmissive
  • Surface: Hard coating
  • Brightness: 350 cd/m^2
  • Contrast Ratio: 800:1 (Min.)
  • Input Voltage: 7.5~12V
  • Rated power: 6-7.5W
  • Signal input: AV + VGA + HDMI (HDMI 1.2)
  • Support Audio Output
  • Weight: 358g
  • HDMI+VGA+2AV LCD controller board x1
  • 10.1 inch 1280x800  IPS LCD panel x1
  • Spaker (Pair) x1
  • LVDS Cable x1
  • Keypad Module(Adjustment Button)         x1
Raspberry Pi 3B+ Tutorial : Using a 10.1” display
Blog Raspberry Pi 3B+ Tutorial : Using a 10.1” display
Jul 27, 2018
Only 17 Left
