Gravity: Analog Heart Rate Monitor Sensor (ECG) for Arduino
$19.90
SKU: SEN0213
  • $19.00 5+ items
  • $18.00 10+ items
  • $16.00 50+ items
Heart rate monitor sensor measures ECG using AD8232 chip for clear signals. Compatible with Arduino and Raspberry Pi. Not a medical device.
The DFRobot Heart Rate Monitor Sensor is used to measure the electrical activity of the heart. This electrical activity can be charted as an ECG and output as an analog reading. An ECG signal can be extremely noisy so we have included an AD8232 chip which will generate a clear signal from the PR and QT Intervals. Using the Arduino IDE "Serial Plotter" feature,  you are also able to view plotted ECG output on  PC!
Gravity: Arduino Heart Rate Monitor Sensor (ECG) -DFRobot
To ease the difficult of using this sensor,  a Gravity Interface is adapted to allow plug&play.  The IO expansion shield is the best match for this sound senor connecting to your Arduino. As this sensor can work at 3.3V which make it compatible with Raspberry Piintel edison, joule and curie.
Analog sensor to monitor heart rate (ECG) with AD8232
NOTE: This product is NOT a medical device and is not intended to be used as such or as an accessory to such nor diagnose or treat any conditions.
  • Input Voltage: 3.3-6V (5V recommended)
  • Output Voltage: 0-3.3V
  • Interface: Analog
  • Operating current: <10mA
  • imension: 35 x 22(mm), 1.378" x 0.866"(in)
  • Interface Type: PH2.0-3P
  • Heart Rate Monitor Sensor x1
  • Sensor cable - Electrode Pads (3 connector) x1
  • Biomedical Sensor Pad x6
  • PH2.0-3P cable x1
 DFRobot Heart Rate Sensor Selection Guide
Blog DFRobot Heart Rate Sensor Selection Guide
Apr 24, 2020
Stephen.Hahn Dec 20, 2025
Pretty accurate and a fun learning project
