TB6600 Stepper Motor Driver (High-Precision 32 Micro-step, 4A)
$20.00
SKU: DRI0043
  • $19.40 3+ items
  • $19.00 5+ items
  • $18.40 10+ items
The stepper motor driver controls two-phase stepping motors, supports micro-step and current adjustments, and offers anti-interference protection.
Purchase this product and earn 200 reward points, which are tied to VIP membership program. Learn More >
The TB6600 Stepper Motor Driver serves as a professional drive solution for two-phase hybrid stepper motors (Types 57 and 42). Compatible with Arduino and other microcontrollers outputting 5V digital pulse signals, this driver features high-speed optocoupler isolation to ensure signal stability and anti-high-frequency interference. Unlike generic alternatives, this module is supported by comprehensive WIKI documentation, verified connection diagrams, and ready-to-use sample code, enabling immediate system integration without the need for complex debugging.
  • Wide Compatibility: Supports 9~42V DC power input; compatible with 2-phase/4-phase hybrid stepper motors.
  • Precise Control: 8 adjustable current settings (0.5-3.5A) and 7 micro-step resolutions (up to 1/32) via onboard DIP switches.
  • Signal Integrity: Signal terminals utilize high-speed optocoupler isolation for superior anti-interference performance.
  • Robust Hardware: Equipped with anti-reverse connection protection and a rugged heat dissipation structure.
  • Recommended Configuration:
  • Controller: DFRduino UNO R3
  • Bipolar Stepper Motor
  • Power: 9~42V DC Power Supply
  • Integrated Protection & Stability
    Designed for reliability in CNC and robotic applications, the driver incorporates a large-area heat sink and automatic semi-flow technology to effectively reduce heat accumulation. The internal circuit features multi-layer safety protection, including input anti-reverse, overheat, over-current, and short-circuit protection, minimizing the risk of hardware failure during operation.
    TB6600 Stepper Motor Driver - DFRobot
     DIY Alarm using Home Assistant, Konnected, and Sonoff RF Bridge
    TB6600 5A Stepper motor driver and Arduino
  • Support 8 kinds of current control
  • Support 7 kinds of micro steps adjustable
  • The interface adopts high-speed optocoupler isolation
  • Automatic semi-flow to reduce heat
  • Large area heat sink
  • Anti-high-frequency interference ability
  • Input anti-reverse protection
  • Overheat, over current and short circuit protection
  • Input Current: 0~5A
  • Output Current: 0.5-4.0A
  • Control Signal: 3.3~24V
  • Power (MAX): 160W
  • Micro Step: 1, 2/A, 2/B, 4, 8, 16, 32
  • Temperature: -10~45℃
  • Humidity: No Condensation
  • Dimension: 96*56*33 mm/ 3.78*2.2*1.3 inches
  • Weight: 0.2 kg
  • Drive IC: TB67S109AFTG
  • TB6600 Stepper Motor Driver x1
    Simon.Holden Aug 27, 2025
    Excellent stepper driver, smooth operation with NEMA motors. Easy wiring, great value!
