Gravity: UART Infrared Carbon Dioxide / CO2 Sensor (0-50000 ppm)
$89.00
SKU: SEN0220
  • $87.50 2+ items
  • $84.50 5+ items
  • $80.00 10+ items
The product is a wide-range CO2 sensor with UART communication, supporting various microcontrollers. It features high sensitivity, low power use, and long lifespan.
Purchase this product and earn 890 reward points, which are tied to VIP membership program. Learn More >
DFRobot released its latest wide range Arduino infrared CO2 sensor, which effective range is up to 0~50000ppm. This sensor is based on non-dispersive infrared (NDIR) technology and has good selectivity and oxygen-free dependency. It integrates temperature compensation and support UART communication mode. Most importantly, the product is easy to use; it is compatible with all types of microcontrollers with UART port, like Arduino, Raspberry Pi and other microcontrollers. Besides, it has a long service life, up to 5 years!
In addition, this UART Infrared CO2 Sensor is a high-performance sensor that combines technology of mature infrared absorption gas detection with precision optical circuit design as well as sophisticated circuit design. It has characteristics such as wide range detection, high sensitivity, high resolution, low power consumption, fast response, anti-water vapor interference, no poisoning, high stability and long life.
It can be widely used in HVAC refrigeration and indoor air quality monitoring, industrial process and safety monitoring, agricultural and animal husbandry production process monitoring, etc..
DFRobot LCD Keypad Shield with UART Infrared CO2 Sensor
This is a 0~50000ppm wide-range CO2 sensor with UART communication port. It supports Arduino, Raspberry Pi, and other microcontrollers. In addition, we also have a 0~5000 ppm high precision infrared sensor with Gravity Analog interface, more easy to use: Gravity Analog Infrared CO2 Sensor (0~5000ppm).
Selection Guide
CO2 Sensor Selection Guide
Figure
SKU
SEN0678
SEN0159
SEN0220
SEN0219
SEN0536
Operation Voltage
3.3 ~ 5V
3.7~5V
4.5~5.5V
4.5~5.5V
3.3V-5V
Output
Gravity: I2C
Gravity: Analog (Analog2.7~4.1V) + 3P Header Digital Output(Alarm):0~VCC Level
Gravity: Analog (Analog Output 0.4~2V)
Gravity: UART (0~3.3V Level)
Gravity: I2C
Measurement Principle
Thermal Conductivity (TC)
Electrochemistry (Solid electrolyte battery principle)
NDIR (non-dispersive infrared)
photoacoustic NDIR
Measurement Range
400 ~ 5000 ppm
0~10000 ppm
0~50000 ppm
400~5000 ppm
400~5000 ppm
Accuracy
±(100 ppm + 10% of reading)
±100ppm@400ppm
±(100ppm + 6% readings)
±(40 ppm + 5% MV)
Response Time
<20s
<20s
<90s
<30s
60s
Average Power
<4.8mW@5V (950μA continuous)
<1W
<430mW@5V
<430mW@5V
<30mW@5V
Operation Temperature
10℃ ~ 40℃
-20℃~50℃
0℃~50℃
0℃~50℃
-10℃~60℃
Operation Humidity
20 ~ 80% RH (non-condensing)
0~95% RH (No condensation)
Dimension (PCB)
32*22 mm
32*42 mm
37*69 mm
21*27.1 mm
32*27*8mm
1. 3-in-1 (CO2, Temp, Humidity) 2. High cost-effectiveness 3. Low power (1μA sleep) 4. Auto compensation 5. I2C Plug and play
1. Large Range 2. Adjustable Alarm Threshold 3. Fast Response 4. Analog Output
1. High Accuracy 2. Long Lifespan 3. Auto Temperature Compensation 4. Water Vapor Interference Resistance 5. Ananglog Output
1. High Accuracy 2. Large Range 3. Long Lifespan 4. Auto Temperature Compensation 5. Water Vapor Interference Resistance 6.3.3V UART Output
1.CO2, temperature, and humidity, three in one 2. Small size of 32*27*8mm 3. Low power, average current<4mA
Add to Cart
  • High sensitivity High resolution
  • Low power consumption
  • Excellent stability
  • Temperature compensation
  • Excellent linear output
  • High cycle life
  • Anti-water vapor interference
  • No poisoning
  • Need 5V power supply, even you are using a 3.3V microcontroller, like Genuino 101/ Raspberry Pi .etc.
  • Gas Detection: Carbon Dioxide (CO2)
  • Operating Voltage: 4.5 ~ 5.5V DC
  • Average Current: <85mA
  • UART output
  • Measuring Range: 0 ~ 50000ppm
  • Accuracy: ± (50ppm + 5% reading)
  • Preheating Time: 3min
  • Response Time: T90 < 30s
  • Operating Temperature: 0 ~ 50 ℃
  • Operating Humidity: 0 ~ 95% RH (no condensation)
  • Service Life: >5 years
  • Board Dimension : 21 * 27.11 mm/ 0.83 * 1.06 inches
  • Weight: 42g
  • UART Infrared CO2 Sensor Probe (0-50000ppm) x1
  • Sensor Converter Board x1
  • 6-Pin Sensor Cable x1
  • PH2.0 Gravity UART Cable x1
  • XH2.54 4-Pin header x1
    How To Make an Air Quality Monitor Logger
    Media How To Make an Air Quality Monitor Logger
    Vigasan
    Oct 03, 2020
    CO2 Concentration Monitoring in Greenhouses
    Blog CO2 Concentration Monitoring in Greenhouses
    May 26, 2023
    How to Choose the Best CO2 Sensor for Arduino / ESP32 Project (2026 Selection Guide)
    Blog How to Choose the Best CO2 Sensor for Arduino / ESP32 Project (2026 Selection Guide)
    Mar 26, 2026
    Jun 26, 2022
    Pauli.Hakala Jun 07, 2026
    Good product to start with and continue futher
    Dadang.Krisdayadi Nov 07, 2025
    Good. Working well. Need about 3-5 minutes for warming up. Hopefully lasting long.
    Chih.Kuo Nov 24, 2021
    Stable reading
    Only 16 Left
