Proto Board - FireBeetle Covers
$3.50
SKU: DFR0481
  • $3.30 5+ items
  • $3.10 10+ items
  • $2.80 50+ items
Low-power micro-controller for IoT with three types: Boards, Covers, Accessories. Proto Board for easy circuit prototyping, compatible with IoT projects.
Purchase this product and earn 35 reward points, which are tied to VIP membership program. Learn More >
DFRobot FireBeetle series is the low-power consumption micro-controller intentionally designed for Internet of Things (IoT). The series micro-controllers aims at IoT node of low-power consumption, attending to build the IoT hardware platform quickly and conveniently. There are three types of FireBeetle, containing Boards (main control), Covers (expansion boards) and related Accessories.
Proto Board is compatible with products of FireBeetle series. There are 14×7 general 2.54mm solder holes in the board of standard spacing. The prototyping boards connect to one master board with VCC, 3.3V and GND soldering pads. These features of Proto Board contribute to it an ideal vehicle for soldering any electronic component. Moreover, the ports compatible with other projects of FireBeetle makes it the best choice for overlay circuit prototypes.
FireBeetle Connection
Today we will teach you How to Make a Smart Colorful Light Based On FireBeetle ESP32 IOT Microcontroller.
Hardware in need:
The instrument not just can record steps (and calories) at real time, but show time. What is special is that the format of showing is pointer.
Hardware in need:
  • Compatible with products in the DFRobot FireBeetle Series, plug and play
  • Cost-Effective
  • Small size, convenient to install
  • 14×7 general 2.54mm soldering pad
  • Dimension: 29.00×58.00mm/ 1.41×2.28 inches
  • Weight: 18 g
  • FireBeetle Covers-Proto Board x1
  • 18 pin-2.54mm pin x4
  • 18 pin-2.54mm long pin header x4
    Make Your Own Arduino Desktop Self-Balancing Robot
    Blog Make Your Own Arduino Desktop Self-Balancing Robot
    Jul 05, 2018
    FireBeetle Board-ESP32 Projects - Let your cigarette lighter wearable
    Blog FireBeetle Board-ESP32 Projects - Let your cigarette lighter wearable
    Jun 07, 2017
