Gravity: I2C 16x2 Arduino LCD with RGB Font Display (Black) V2.0
$11.90
SKU: DFR0554
  • $11.30 3+ items
  • $10.70 5+ items
  • $10.15 10+ items
16x2 RGB LCD with I2C interface offers 16 million color combinations, supports scrolling and cursor movement, and is compatible with Arduino libraries.
Accustomed to the same LCD screen, do you want to have a different experience? DFRobot LCD1602 will bring you a new visual feeling, It is not the same as the previous LCD monochrome screen, supports RGB full-color font, can provide 16 million kinds of color combinations. DFRobot Gravity I2C 16x2 Arduino LCD with RGB Font Display use universal Gravity I2C interface, it means only two communication lines, you can realize communication and backlight control. The LCD screen can display 2x16 characters, support screen scrolling, cursor movement and other functions. Through dedicated Arduino library, you can complete all the design without cumbersome wiring and complex code.
  • Operating Voltage: 3.3V~5.0V
  • Operating Current: ≤60mA
  • Display Description: 16*2
  • Communication Mode: I2C
  • Backlight: RGB can adjust backlight
  • Operating Temperature: -20 to +70℃
  • Storage Temperature: -30 to +80℃
  • Dimension: 87.0*32.0*13.0mm/3.43*1.26*0.51in
  • Gravity: I2C 16x2 Arduino LCD with RGB Font Display (Black) V2.0 x1
  • Gravity 4Pin I2C/UART Sensor Cable x1
    Talking Wood / Pellet Stove High Temperature Sensor
    Projects Talking Wood / Pellet Stove High Temperature Sensor
    KGray
    Feb 27, 2023
    Evan.Levy Mar 11, 2026
    OMG… so it’s a 16x2 I2C LCD display. Functionally it works exactly as expected. Nothing special or wrong with it when it comes to functionality. But visually? OMG is it beautiful! I honestly don’t think I could ever use a normal blue/green backlit LCD display ever again after using this. It is a bit more expensive than the standard displays, but it isn't standard, and worth the extra cost in my opinion. DFRobot is known for quality, not for being cheap, and that definitely shows here. Great quality PCB design (like all of DFRobot’s products) and a sturdy metal housing over the LCD display as well. I attached pictures of a metronome project that simply displays the BPM number, but the pictures really don’t capture the full beauty of the display. I also bought the other versions and will leave comments for them too, but the “Black” background with RGB pixels is the winner in my opinion. That said, you may prefer the other variants, so make your own choice. FYI: For the black background version, there is a small color bleed over the black background. It’s not a serious problem in my opinion. It still looks absolutely gorgeous.
    wajdi. Oct 21, 2022
    Very good as description
