Gravity: BMP388 Barometric Pressure Sensors
$6.90
SKU: SEN0251
  • $6.70 3+ items
  • $6.50 5+ items
  • $6.20 10+ items
BMP388 sensor measures temperature and pressure, supports Arduino, offers low power consumption and high resolution, enabling altitude and indoor positioning.
This new released BMP388 barometric pressure sensor by DFRobot is equipped with the functionality of temperature and pressure measurement. It supports Arduino code control. Compared with the earlier version of BMP180, BMP280, and BMP388, this sensor exhibits lower power consumption, higher resolution and higher sampling rate.
The barometric pressure is usually used to measure barometric pressure and temperature. But besides that, we can also use the sensor to measure the altitude and the relative floor height due to the fact that there is a certain relationship between altitude and barometric pressure. What’s more, BMP388 enables accurate GPS tracking. So with an IMU sensor and BMP388, we can experience 3D indoor positioning and navigation.
BMP388 is based on Bosch’s mature Piezo resistive pressure sensor technology featuring high accuracy as well low power consumption and high EMC robustness.
The sensor features an accuracy of about ±8Pa, which is equivalent to about ±0.5m difference in altitude, and an absolute accuracy temperature of ±0.5℃ for a temperature range between 0℃ and 65℃.
Selection Guide
Pressure/Altitude Sensor Selection Comparison Table
Figure
SKU
SEN0664
SEN0666
SEN0665
SEN0667
SEN0423
SEN0251
Add to Cart
Chip/Module Type
Bosch BMP585
Bosch BMP585
Bosch BMP581
Bosch BMP581
Bosch BMP390L
Bosch BMP388
Size/Volume
Compact module
Ultra-small PCB
Compact module
Ultra-small PCB
Ultra-small PCB
Compact module
Power Consumption
∼700μA
200μA / 2μA sleep
∼700μA
200μA / 2μA sleep
54μA sleep / max ∼650μA
~0.5mA
Interface Protocol
I2C / UART, plug & play
I2C / SPI / I3C
I2C / SPI / I3C
I2C / SPI
I2C / SPI
Accuracy / Key Features
±0.3hPa / Industrial protection
±0.3hPa + Waterproof & Chemical resistant
±0.3hPa / Ultra-low noise
±0.50hPa / ±3Pa (∼±0.25m) / High stability
±8Pa (∼±0.5m) / Temp ±0.5∘C
Ideal Scenarios
Industrial / Agricultural environmental detection
Outdoor weather stations / Environmental monitoring device integration
Drone altitude control / High-precision pressure data logging
Battery-powered IoT / Micro-drone project integration
Drone altitude control / High-precision pressure & altitude detection
Basic pressure measurement / Indoor positioning / GPS enhancement
  • Low power consumption
  • Low noise
  • High resolution
  • Small dimensions
  • Best-in-class offset temperature coefficient(-20℃-65℃@700-1100hPa)
  • Operating Voltage: 3.3V-5.5V
  • Operating Current: 0.5mA
  • Operating Range: 300-1250 hPa
  • Relative Accuracy: ±8 Pa (equivalent to ±0.50m @700-900hPa, 25℃-40℃)
  • Absolute Accuracy: ±50 Pa(0℃-65℃@300-1100hPa)
  • Temperature Coefficient Offset: ±0.75 Pa/K(-20℃-65℃@700-1100hPa)
  • Absolute Accuracy Temperature: ±0.5℃(@0℃-65℃)
  • Operating Temperature: -40℃~80℃ (more accurate in 0℃-65℃)
  • External Dimension: 22mm x 30mm
  • Mounting Hole Position: 15mm
  • Mounting Hole Dimension: inside diameter 3mm/ outside diameter 6mm
  • Interface: Gravity-I2C 4Pin or SPI (SPI is only used at 3.3V)
  • Gravity:BMP388 Barometric Pressure Sensor module x1
  • PH2.0-4P sensor cable x1
