Dedicated Design, Superior Texture
Titan case uses conflict aesthetics to combine functional design considerations with sci-fi elements. Understated color selection and layered surface treatment technology create a kind of design, flat but with unlimited potential.
Two Models, Balancing Extensibility And Integrity
Invisible quick-release cover design. A complete computer after fastening, or an open hardware development platform after quick disassembling.
Note:
1. Titan case is designed for LattePanda 2 Alpha & 2 Delta, not compatible with LattePanda V1.0 and LattePanda 3 Delta.
2. Use M4 screws for the two middle holes in the bottom case, and make sure to control their length to avoid using screws that are too long, as they could damage the PCB when fully tightened. The maximum length for screwing from the outside of the shell to the inside is 5mm; screws that are 7mm long will touch the PCB. If you're mounting the case onto a device with a thickness of 'a' mm, the maximum screw length you should use is (a+5) mm.
Feb 06, 2020
This is a nicely designed case that’s very easy put together. The cover as access panels to get at the GPIO headers on both sides of the board. Plenty of room at the bottom for the Wi-Fi / Bluetooth antennas. You can also mount your M.2 devices in the same will vented bottom panel. The power button on the side makes it very easy to power up you unit. The power on LED’s are placed on the other side marking it easy to see if you board is powered up. As a Alpha user I highly recommend this case!
Mar 21, 2026
Great fit and good cooling. Simple assembly
May 10, 2025
This is an amazing product
