ESP32-WROVER-B WiFi/BLE Module with 8MB PSRAM (IPEX antenna)
$5.00
SKU: DFR0623
  • $4.90 3+ items
  • $4.80 5+ items
  • $4.60 10+ items
A versatile WiFi-BT-BLE-MCU module with low power usage, featuring dual CPU cores, adjustable frequencies, and extensive peripheral support for various applications.
The ESP32-WROVER-B is a generic Wi-Fi, Bluetooth (v4.2 BR/EDR/BLE), and MCU module for integration. It is based on the ESP32-D0WD chip, featuring two individually-controlled CPU cores (80-240 MHz). This module includes 4 MB of SPI flash and 8 MB (64-Mbit) of SPI PSRAM. Connectivity to an external antenna is provided via an IPEX connector. It supports a wide range of peripherals including SD card, UART, SPI, I2C, I2S, ADC, and DAC. The module is pre-certified (FCC, CE-RED, IC, TELEC, etc.) and operates on a 2.7V to 3.6V supply.
This module employs the ESP32-D0WD chip of ESP32 series and also combines 2.4GHz WiFi and dual-mode Bluetooth. There are two CPU cores that can be individually controlled, and the CPU clock frequency is adjustable from 80MHz to 240 MHz. The user may also power off the CPU and make use of the low-power co-processor to constantly monitor the peripherals for changes or crossing thresholds. ESP32 integrates a rich set of peripherals, including capacitive touch sensors, Hall sensors, SD card interface, Ethernet, high-speed SPI, UART, I2C, and I2S.
The integration of Bluetooth, Bluetooth LE and WiFi ensures that a wide range of applications can be covered: using WiFi allows a large physical range and direct connection to the Internet through a WiFi router while using Bluetooth allows the user to conveniently connect to the phone or broadcast low energy beacons for its detection. The sleep current of the ESP32 chip is less than 5 µA, making it suitable for battery-powered and wearable electronics applications. The module supports a data rate of up to 150 Mbps, and 20 dBm output power at the antenna to ensure the widest physical range. As such the module does offer industry-leading specifications and the best performance for electronic integration, range, power consumption, and connectivity.
The operating system chosen for ESP32 is freeRTOS with LwIP; TLS 1.2 with hardware acceleration is built-in as well. Secure (encrypted) over the air (OTA) upgrade is also supported so that users can upgrade their products even after their release.
DFR0623, WiFi, Bluetooth, ESP32, IPEX antenna, WROVER, IoT, Radio
Dimension Diagram
Certification
  • RF Certification: FCC/CE-RED/IC/TELEC/KCC/SRRC/NCC
  • Bluetooth Certification: BQB
  • Green Certification: RoHS/REACH
Test
  • Reliability: HTOL/HTSL/uHAST/TCT/ESD
Wi-Fi
  • Protocols: 802.11 b/g/n (802.11n up to 150Mbps)
                      A-MPDU and A-MSDU aggregation and 0.4µs guard interval support
  • Frequency Range: 2.4GHz ~2.5GHz
Bluetooth
  • Protocols: Bluetooth v4.2 BR/EDR and BLE specification
  • Radio: NZIF receiver with-97 dBm sensitivity
                 Class-1, class-2 and class -3 transmitter                  AFH
  • Audio: CVSD and SBC
Hardware
  • Module Interface: SD card, UART, SPI, SDIO, I2C, LED PWM, Motor PWM, I2S, IR, pulse counter, GPIO, capacitive touch sensor, ADC, DAC
  • On-chip Sensor: Hall sensor
  • Integrated Crystal: 40 MHz crystal
  • Integrated SPI Flash: 4MB
  • Integrated PSRAM: 8MB
  • Operating Voltage/Power Supply: 2.7V~3.6V
  • Minimum Current Delivered by Power Supply: 500mA
  • Recommended Operating Temperature Range: –40°C~65°C
  • Package Size: (18.00±0.10)mm×(31.40±0.10)mm×(3.30±0.10)mm
  • ESP32 WIFI+BLE Module (IPEX antenna) x1
ESP32 cpplinq Tutorials Menu
Blog ESP32 cpplinq Tutorials Menu
Apr 25, 2021
Blog ESP32 HTTP server Tutorials Menu
Apr 25, 2021
ESP32 Soft AP Tutorials Menu
Blog ESP32 Soft AP Tutorials Menu
Apr 25, 2021
ESP32 MicroPython Tutorials Menu
Blog ESP32 MicroPython Tutorials Menu
Apr 01, 2021
ESP32 PS3 and PS4 Tutorials Menu
Blog ESP32 PS3 and PS4 Tutorials Menu
Apr 25, 2021
ESP32 Espruino Tutorials Menu
Blog ESP32 Espruino Tutorials Menu
Apr 25, 2021
