ESP32-WROVER-B WiFi/BLE Module with 8MB PSRAM (IPEX antenna)
$5.00
SKU: DFR0623
  • $4.90 3+ items
  • $4.80 5+ items
  • $4.60 10+ items
A versatile WiFi-BT-BLE-MCU module with low power usage, featuring dual CPU cores, adjustable frequencies, and extensive peripheral support for various applications.
ESP32‑WROVER‑B WiFi + Bluetooth Module (IPEX Antenna) is a high‑performance wireless MCU module designed for advanced IoT and embedded connectivity applications. Built around the ESP32 dual‑core processor, this WiFi and Bluetooth communication module integrates 4MB SPI Flash and 8MB SPI PSRAM for memory‑intensive edge computing tasks. Dual‑mode wireless connectivity enables both long‑range network communication and low‑power device interaction. With rich peripheral interfaces and a compact surface‑mount footprint, this wireless microcontroller module simplifies integration into smart devices, robotics systems, industrial monitoring nodes, and connected consumer electronics.
Dual‑Core Wireless Processing Architecture
This IoT communication module uses the ESP32‑D0WD chipset featuring two independently controlled CPU cores running between 80 MHz and 240 MHz. Flexible clock control enables performance tuning or power optimization depending on application needs. A low‑power co‑processor allows continuous peripheral monitoring while the main cores remain powered down, enabling efficient event‑driven operation. Combined WiFi and Bluetooth connectivity expands communication options for mobile devices, routers, and distributed sensing nodes across a wide range of embedded networking scenarios.
Rich Peripheral Integration for Embedded Systems
This wireless MCU board integrates an extensive set of peripherals supporting complex embedded designs without external controllers. Supported interfaces include SD card, UART, SPI, I2C, I2S, ADC, DAC, PWM outputs, infrared communication, pulse counters, and capacitive touch sensors. Built‑in Hall sensing and GPIO expansion provide additional hardware interaction capabilities. Such extensive peripheral support allows rapid development of connected controllers, data acquisition systems, and intelligent edge devices.
High‑Performance Wireless Connectivity
The compact wireless communication unit integrates 2.4GHz WiFi alongside Bluetooth v4.2 BR/EDR and BLE, allowing both high‑bandwidth internet connectivity and low‑energy device pairing. WiFi enables direct network access through routers while Bluetooth supports smartphone interaction and beacon broadcasting. Data transmission rates up to 150 Mbps and up to 20 dBm antenna output power enable long communication ranges. Ultra‑low sleep current below 5 µA supports battery‑powered designs such as wearable electronics and remote IoT sensor nodes.
Secure Embedded Software Ecosystem
This embedded connectivity module operates with FreeRTOS and the LwIP networking stack, providing a robust real‑time software environment for connected devices. Built‑in TLS 1.2 hardware acceleration enhances secure communication for cloud and network applications. Secure encrypted over‑the‑air firmware updates allow product maintenance and feature upgrades after deployment, making the wireless MCU module suitable for long‑life smart hardware products and scalable IoT deployments.
DFR0623, WiFi, Bluetooth, ESP32, IPEX antenna, WROVER, IoT, Radio
Figure: Dimension Diagram
Applications include IoT gateways, smart home controllers, wearable electronics, wireless sensor networks, robotics communication nodes, and cloud‑connected industrial monitoring devices. The combination of dual‑core processing, integrated memory, secure networking support, and multiple communication interfaces enables efficient development of intelligent connected systems across consumer, industrial, and educational environments.
  • ESP32‑D0WD dual‑core processor with adjustable 80–240 MHz CPU frequency
  • Integrated WiFi 802.11 b/g/n and Bluetooth v4.2 BR/EDR/BLE
  • 4MB SPI Flash and 8MB SPI PSRAM integrated
  • IPEX connector for external antenna
  • Support for SD card, UART, SPI, SDIO, I2C, I2S, ADC and DAC
  • Built‑in Hall sensor and capacitive touch sensing capability
  • Data rates up to 150 Mbps with up to 20 dBm RF output power
  • Ultra‑low sleep current below 5 µA for battery applications
  • FreeRTOS operating system with LwIP networking stack
  • Hardware‑accelerated TLS 1.2 and secure OTA firmware upgrade support
  • Pre‑certified wireless module (FCC, CE‑RED, IC, TELEC and more)
  • IoT gateway devices
  • Smart home controllers
  • Wireless sensor networks
  • Wearable electronics
  • Robotics communication systems
  • Industrial monitoring nodes
  • Connected consumer electronics
  • Edge computing and cloud‑connected devices
Certification
  • RF Certification: FCC/CE-RED/IC/TELEC/KCC/SRRC/NCC
  • Bluetooth Certification: BQB
  • Green Certification: RoHS/REACH
Test
  • Reliability: HTOL/HTSL/uHAST/TCT/ESD
Wi‑Fi
  • Protocols: 802.11 b/g/n (802.11n up to 150Mbps)
  • A‑MPDU and A‑MSDU aggregation and 0.4µs guard interval support
  • Frequency Range: 2.4GHz ~2.5GHz
Bluetooth
  • Protocols: Bluetooth v4.2 BR/EDR and BLE specification
  • Radio: NZIF receiver with -97 dBm sensitivity
  • Transmitter: Class‑1, class‑2 and class‑3 transmitter
  • Features: AFH
  • Audio: CVSD and SBC
Hardware
  • Module Interface: SD card, UART, SPI, SDIO, I2C, LED PWM, Motor PWM, I2S, IR, pulse counter, GPIO, capacitive touch sensor, ADC, DAC
  • On-chip Sensor: Hall sensor
  • Integrated Crystal: 40 MHz crystal
  • Integrated SPI Flash: 4MB
  • Integrated PSRAM: 8MB
  • Operating Voltage/Power Supply: 2.7V~3.6V
  • Minimum Current Delivered by Power Supply: 500mA
  • Recommended Operating Temperature Range: –40°C~65°C
  • Package Size: (18.00±0.10)mm×(31.40±0.10)mm×(3.30±0.10)mm
  • ESP32 WIFI+BLE Module (IPEX antenna) ×1
ESP32 cpplinq Tutorials Menu
Blog ESP32 cpplinq Tutorials Menu
Apr 25, 2021
Blog ESP32 HTTP server Tutorials Menu
Apr 25, 2021
ESP32 Soft AP Tutorials Menu
Blog ESP32 Soft AP Tutorials Menu
Apr 25, 2021
ESP32 MicroPython Tutorials Menu
Blog ESP32 MicroPython Tutorials Menu
Apr 01, 2021
ESP32 PS3 and PS4 Tutorials Menu
Blog ESP32 PS3 and PS4 Tutorials Menu
Apr 25, 2021
ESP32 Espruino Tutorials Menu
Blog ESP32 Espruino Tutorials Menu
Apr 25, 2021
