Gravity: Analog Flame Sensor For Arduino
$2.50
SKU: DFR0076
Arduino-compatible flame sensor detects fire with a 60-degree probe angle, operates from -25°C to 85°C, and supports various platforms like Raspberry Pi.
This Arduino flame sensor can be used to detect fire or other wavelength at 760 nm ~ 1100 nm light. In the fire-fighting robot game, the flame plays an important role in the probe, which can be used as the robot's eyes to find fire source or football. It can make use of fire-fighting robots, soccer robots.
The Flame sensor has probe angle of 60 degrees, two M3 mounting holes is provided to install on various platforms.
This arduino flame sensor's operating temperature is -25 degrees Celsius to 85 degrees Celsius, in the course of the flame it should be noted that the probe distance from the flame should not be too close inorder to avoid damage.
Arduino Flame Sensor Demo Project 2
This sensor can sense flame sensitively!!
 This sensor uses Gravity interface, and works from 3.3V-5V  which is able to be compatible with various platforms such as Arduino, Raspberry Pi, Intel Galileo, Curie and Joule
Improvement
  • Standard assembling structure (two 3mm holes with multiple of 5cm as interval)
  • High quality connector
  • Immersion gold surface
  • Supply Voltage: 3.3V to 5V
  • Detection range: 20cm (4.8V) ~ 100cm (1V)
  • Rang of Spectral Bandwidth : 760nm to 1100nm
  • Responsive time : 15us
  • Interface: Analog
  • Size:22x30mm (0.87x1.18in)
  • Flame Sensor x1
  • Analog cable x1
Ziad.Naesah Dec 13, 2025
The Gravity: Analog Flame Sensor for Arduino is a reliable, low-cost solution for detecting open flames. While it’s not suitable for professional fire alarm systems, it excels in learning, prototyping, and hobbyist applications.
Out Of Stock
