Fermion: SHT31-F Digital Temperature & Humidity Sensor (Breakout)
$9.70
SKU: SEN0332
  • $9.40 3+ items
  • $9.20 5+ items
  • $8.90 10+ items
Digital sensor with SHT31-F IC offers precise temperature and humidity measurements, low power consumption, and IP67 protection. Ideal for IoT applications.
Purchase this product and earn 97 reward points, which are tied to VIP membership program. Learn More >
This Digital Temperature & Humidity Sensor Breakout Board is based upon the Sensirion SHT31-F sensor IC. Thanks to Sensirion’s CMOSens® technology, highly integrated capacitive humidity sensing components and band-gap temperature sensing components, the SHT31-F offers high reliability and long-term stability with low power consumption, fast response and strong anti-interference ability. The sensor supports I2C communication, and is compatible with 3.3V/5V controllers like Arduino, micro:bit, ESP32. It is easy to achieve precise and high-reliability temperature and humidity sensing for urban environment monitoring, intelligent buildings, industrial automation, smart home and other Internet of Things applications.
SHT31-F is the standard version of the SHT3x series. It provides humidity accuracy ±2% RH @ 0% RH~100% RH (at 25°C), and temperature accuracy± 0.2°C @ 0°C ~90°C (typical).
The SHT31-F chip features a PTFE membrane dedicated to protecting the sensor opening from liquids and dust according to IP67. It thus allows the sensor to work under harsh environmental conditions, where spray water and high exposure to dust might be challenging for accurate sensor performance. Due to minimal package volume and the membrane’s high water vapor permeability, the response time of the relative humidity and temperature signal is identical to the value achieved by the uncovered sensor. Although the membrane option provides perfect protection against water and dust ingress, it does not in general prevent contamination from volatile chemicals.
Digital Temperature and Humidity Sensor Selection Guide
Product Name SHT30 SHT31 SHT31-F SHT35
SKU SEN0330 SEN0331 SEN0332 SEN0333
IC Type SHT30-DIS-B SHT31-DIS-B SHT31-DIS-F SHT35-DIS-B
Typ. RH
Accuracy (%RH)
±2@10-90%RH ±2@0-100%RH ±2@0-100%RH ±1.5@0-80%RH
Typ.
Temperature (°C)
±0.2@0-65 ±0.2@0-90℃ ±0.2@0-90℃ ±0.1@20-60℃
Price $6.9 $8.9 $9.7 $16.9
Feature Cheap Cost-Effective IC Dustproof High Accuracy
  • High precise, internal auto-calibrated, digital output
  • Low power consumption, fast response, and strong anti-interference
  • IP67 dust-proof protective film
  • Compatible with 3.3V/5V controllers
  • Urban Environmental Monitoring
  • Intelligent Building, Smart Home
  • Grain Storage
  • Plant and animal breeding system
  • Operating Voltage: 2.15~5.5V
  • Operating Current: <1.5mA
  • Humidity Detection Range: 0%RH~100%RH
  • Humidity Accuracy: ±2%RH@0%RH~100%RH(at 25℃)
  • Temperature Detection Range: -40℃~125℃
  • Temperature Accuracy: ±0.2℃@0℃~90℃(Typical)
  • Communication: I2C
  • Outline Dimension: 19x16mm/0.75x0.63”
  • Mounting Hole Size: 2mm/0.08”
  • Mounting Hole Pitch: 15mm/0.59”
  • DFRobot SHT31-F Digital Temperature and Humidity Sensor x1
  • Black 2.54-6P Single Row x1
Blog Digital Temperature and Humidity Sensor Selection Guide
Apr 24, 2020
arnaud.matton Feb 14, 2026
A very good sensor for monitoring humidity and temperature in my rooms.
