Fermion: SHT35 Digital Temperature & Humidity Sensor (Breakout)
$16.90
SKU: SEN0333
  • $16.30 3+ items
  • $16.10 5+ items
  • $15.50 10+ items
Digital sensor using SHT35 IC offers reliable, precise temperature and humidity detection, supports I2C, compatible with Arduino, ESP32, and micro:bit.
Purchase this product and earn 169 reward points, which are tied to VIP membership program. Learn More >
This Digital Temperature & Humidity Sensor Breakout Board is based upon the Sensirion SHT35 sensor IC. Thanks to Sensirion’s CMOSens® technology, highly integrated capacitive humidity sensing components and band-gap temperature sensing components, the SHT35 offers high reliability and long-term stability with low power consumption, fast response and strong anti-interference ability. The sensor supports I2C communication, and is compatible with 3.3V/5V controllers like Arduino, micro:bit, ESP32. It is easy to achieve precise and high-reliability temperature and humidity sensing for urban environment monitoring, intelligent buildings, industrial automation, smart home and other Internet of Things applications.
SHT35 is the high-end version of the SHT3x series. It provides humidity accuracy ±1.5%RH @ 0%RH~80%RH (at 25°C), and temperature accuracy±0.2°C@ -40℃-90℃ (typical).
Digital Temperature and Humidity Sensor Selection Guide
Product Name SHT30 SHT31 SHT31-F SHT35
SKU SEN0330 SEN0331 SEN0332 SEN0333
IC Type SHT30-DIS-B SHT31-DIS-B SHT31-DIS-F SHT35-DIS-B
Typ. RH
Accuracy (%RH)
±2@10-90%RH ±2@0-100%RH ±2@0-100%RH ±1.5@0-80%RH
Typ.
Temperature (°C)
±0.2@0-65 ±0.2@0-90℃ ±0.2@0-90℃ ±0.1@20-60℃
Price $6.9 $8.9 $9.7 $16.9
Feature Cheap Cost-Effective IC Dustproof High Accuracy
  • High precise, internal auto-calibrated, digital output
  • Low power consumption, fast response, and strong anti-interference
  • Compatible with 3.3V/5V controllers
  • Urban Environmental Monitoring
  • Intelligent Building, Smart Home
  • Grain Storage
  • Plant and animal breeding system
  • Operating Voltage: 2.15~5.5V
  • Operating Current: <1.5mA
  • Humidity Detection Range: 0%RH~100%RH
  • Humidity Accuracy: ±1.5%RH@0%RH~80%RH(at 25℃)
  • Temperature Detection Range: -40℃~125℃
  • Temperature Accuracy: ±0.2℃@-40℃~90℃ (Typical)
  • Communication: I2C
  • Outline Dimension: 19x16mm/0.75x0.63”
  • Mounting Hole Size: 2mm/0.08”
  • Mounting Hole Pitch: 15mm/0.59”
  • DFRobot SHT35 Digital Temperature and Humidity Sensor x1
  • Black 2.54-6P Single Row x1
Blog Digital Temperature and Humidity Sensor Selection Guide
Apr 24, 2020
Only 15 Left
