Fermion: SHT35 Digital Temperature & Humidity Sensor (Breakout)
$16.90
SKU: SEN0333
Digital sensor using SHT35 IC offers reliable, precise temperature and humidity detection, supports I2C, compatible with Arduino, ESP32, and micro:bit.
This Digital Temperature & Humidity Sensor Breakout Board is based upon the Sensirion SHT35 sensor IC. Thanks to Sensirion’s CMOSens® technology, highly integrated capacitive humidity sensing components and band-gap temperature sensing components, the SHT35 offers high reliability and long-term stability with low power consumption, fast response and strong anti-interference ability. The sensor supports I2C communication, and is compatible with 3.3V/5V controllers like Arduino, micro:bit, ESP32. It is easy to achieve precise and high-reliability temperature and humidity sensing for urban environment monitoring, intelligent buildings, industrial automation, smart home and other Internet of Things applications.
SHT35 is the high-end version of the SHT3x series. It provides humidity accuracy ±1.5%RH @ 0%RH~80%RH (at 25°C), and temperature accuracy±0.2°C@ -40℃-90℃ (typical).
Digital Temperature and Humidity Sensor Selection Guide
Product Name SHT30 SHT31 SHT31-F SHT35
SKU SEN0330 SEN0331 SEN0332 SEN0333
IC Type SHT30-DIS-B SHT31-DIS-B SHT31-DIS-F SHT35-DIS-B
Typ. RH
Accuracy (%RH)
±2@10-90%RH ±2@0-100%RH ±2@0-100%RH ±1.5@0-80%RH
Typ.
Temperature (°C)
±0.2@0-65 ±0.2@0-90℃ ±0.2@0-90℃ ±0.1@20-60℃
Price $6.9 $8.9 $9.7 $16.9
Feature Cheap Cost-Effective IC Dustproof High Accuracy
  • High precise, internal auto-calibrated, digital output
  • Low power consumption, fast response, and strong anti-interference
  • Compatible with 3.3V/5V controllers
  • Urban Environmental Monitoring
  • Intelligent Building, Smart Home
  • Grain Storage
  • Plant and animal breeding system
  • Operating Voltage: 2.15~5.5V
  • Operating Current: <1.5mA
  • Humidity Detection Range: 0%RH~100%RH
  • Humidity Accuracy: ±1.5%RH@0%RH~80%RH(at 25℃)
  • Temperature Detection Range: -40℃~125℃
  • Temperature Accuracy: ±0.2℃@-40℃~90℃ (Typical)
  • Communication: I2C
  • Outline Dimension: 19x16mm/0.75x0.63”
  • Mounting Hole Size: 2mm/0.08”
  • Mounting Hole Pitch: 15mm/0.59”
  • DFRobot SHT35 Digital Temperature and Humidity Sensor x1
  • Black 2.54-6P Single Row x1
Blog Digital Temperature and Humidity Sensor Selection Guide
Apr 24, 2020
Michael.Samyn Mar 09, 2026
It works fine. Easy to connect and to import the library. The product is of good quality
