The DFRobot heart rate and oximeter sensor integrates the Maxim MAX30102 chip and an MCU with heart rate and oximetry algorithm.
The MAX30102 uses PPG(PhotoPlethysmoGraphy) to measure data, which will be converted into heart rate and oximetry values when processed by the MCU, then output through I2C or UART, making the sensor easy to use and greatly reducing resource occupation of main controller. Meanwhile, the corresponding upper computer is provided to allow you to conveniently read data by a PC.
Note:
1.The pressure may change when the finger is directly pressed down the sensor, which will affect the data output. So please try to fix the sensor on your finger.
2.Wear the sensor on your finger and there is no difference in the direction of wearing.
3. This product is not a professional medical instrument and should not be used as an auxiliary accessory in diagnosis and treatment.
Update
The sensor V2.0 is equipped with a microprocessor that integrates heart rate and oximetry algorithm, which can directly output the relevant data. And it supports I2C/UART communication.
Mar 13, 2025
The package arrived on time and was packaged really well. I haven't tested the sensor yet. I will give my feedback once I test it.
