The Text-to-Speech module enables easy integration of voice functionality into various projects. It supports both Chinese and English languages, providing clear and natural pronunciation. The module can also broadcast the current time and environmental data, and when combined with a speech recognition module, it enables conversational interactions with your projects. The module uses I2C and UART communication modes, with a gravity interface, ensuring compatibility with most main controllers on the market, such as Arduino, micro:bit, Firebeetle Series, LattePanda, and Raspberry Pi. Additionally, it includes a built-in speaker, eliminating the need for an external one. The primary applications for this module include robot voice, voice broadcast, voice prompt, and text reading.
Bilingual Support (Chinese and English)
The module supports both Chinese and English, as well as mixed reading in both languages, making it versatile for a variety of applications. This allows for seamless integration into projects requiring multilingual voice output.
Built-in Speaker
The included speaker simplifies the setup process, allowing immediate use without the need for additional components. This feature makes it easy to add voice functionality to projects without worrying about speaker compatibility or additional wiring.
Easy Communication
With both I2C and UART communication modes, the module is compatible with a wide range of main controllers, providing flexibility in design and integration. The gravity interface further simplifies the connection process.
Text Control Identifiers
The module supports multiple text control identifiers, enhancing its ability to deliver more natural and accurate speech. This feature is crucial for projects that require precise voice outputs and minimal errors in pronunciation.
Note: the addresses of the speech synthesis module and micro: bit motor driver board are the same, so they cannot be used together.
V2.0 Function Updates:
1. More natural pronunciation
2. Fewer pronunciation errors for polyphone characters
3. The option to select a pronouncer has been cancelled
Board Overview
Connection Diagram
Mar 27, 2026
This was easy to use. I feel that the English voice was a little hard to understand at time. But, for the money, it's great.
Dec 13, 2025
The Gravity: Text to Speech Voice Synthesizer Module V2.0 is an excellent module for adding voice feedback to your microcontroller projects. Its bilingual support, adjustable voice parameters, and ease of integration make it a top choice for educational, smart home, and interactive electronics projects.
Apr 15, 2025
Fast shipping, order is correct item, I didn't give it 5 stars because the synthesizer has a strong chinese accent, either then that it works fine.
