The Gravity 4Pin I2C/UART sensor cable is a standard Gravity series 4-Pin cable with 50cm length. One side is PH2.0-4p connector and the other side is XH2.54 DuPont port, compatible with standard breadboard pin pitch for convenient DIY connection.
Besides, the cable uses color code design to distinguish between the positive and negative power supply, I2C SDA SCL, UART RX TX. Easy to recognize and use.
Jul 17, 2021
Fast Shipping Exactly as described Will buy again
Nov 16, 2021
Great for connecting various sensor boards to expansion board.
