This industrial-grade RS485 shield from DFRobot is specially designed to expand two parallel RS485 ports (terminal) with high reliability for LattePanda Alpha, LattePanda Delta and LattePanda 3 Delta. Employing FTDI USB to serial port chip and industrial-grade isolated transceiver module, the shield comes with the characteristics of signal isolation, power isolation, lightning and surge protection, transient impulse voltage resistance, and bus protection so that it supports reliable data transmission and also can effectively protect your LattePanda mainboard for providing a high-reliability connection for point-to-point.
The product employs a stackable connection, making it able to be easily fixed onto LattePanda mainboard by copper columns without blocking the heat dissipation area of the mainboard. It can be safely applied in industrial scenarios.
Plug the shield into LattePanda Alpha & Delta
Application:
Facilitate the development and use of industrial-grade RS232 communication on Windows (compatible with Linux)
Jun 18, 2025
Very Good Product. Very Supportive Customer Service and Fast Delivery.
Apr 22, 2025
Easy configured and use
