Get this camera to help you see what you cannot see and touch! This small inspection camera employs a 3-in-1 USB+micro USB+Type-C design for being conveniently used on a variety of devices to take photos or videos in narrow and dark environments. The integrated ultra-bright LEDs and 1200P HD camera make it able to present images with color effect while retaining high resolution and quality even in dark places. In addition, the lens is equipped with automatic exposure and blue light technology, which can effectively filter stray light, restore real scenes, and make images clearer.
The camera lens is sealed with special glue and has an IP67 rating of oil and water resistance, so you can safely use it to take pictures underwater. The camera can be used on Raspberry Pi, NVIDIA, LattePanda, and other motherboards and is suitable for car maintenance, underwater viewing, wildlife surveillance, underground detection, large equipment check, construction sites, hard-to-reach areas, etc.
Note:
1. To use this camera, your phone needs to support OTG function.
2. IOS system and iPhone are not supported.
