Gravity: LED Switch for Arduino / micro:bit (Green)
$4.50
SKU: DFR0789-G
  • $4.40 3+ items
  • $4.30 5+ items
  • $4.10 10+ items
LED self-lock switch button lights up in five colors when pressed, providing visual feedback. Ideal for interactive projects with micro:bit.
This is a simple LED-illuminated self-lock switch button. It’s just like a basic switch button, but it lights up color(red/yellow/green/blue/white) when pressed down, which gives you visual feedback. These little buttons can be used with micro: bit to realize various fun interactive projects, such as switch, backlight keyboard, music player panel, and recording control panel.
Note: The module comes with self-lock function. When the button is pressed down, the module outputs High, and the LED lights up. When being pressed again, the module outputs Low and the LED turns off.
Gravity: LED Switch
Connection Diagram
  • Internal LED turns On when the button is pressed down
  • Operating Voltage: +3.3-5V (3.3V is recommended)
  • Output: digital
  • Connector: PH2.0-3P
  • Dimension: 27×26.5mm
  • Colors Available: red, yellow, green, blue, white
  • Gravity: LED Switch x1
  • Digital Sensor Connector x1
    Eye led push button for Arduino and Raspberry
    Projects Eye led push button for Arduino and Raspberry
    RoniBandini
    Nov 02, 2022
    Ronald.Sdeyb Nov 14, 2021
    so good
    Only 15 Left
