Gravity: LED Switch for Arduino / micro:bit (White)
$4.50
SKU: DFR0789-W
  • $4.40 3+ items
  • $4.30 5+ items
  • $4.10 10+ items
LED-illuminated switch with self-lock function lights up in various colors when pressed. Ideal for projects with micro: bit. Outputs High/Low signals.
This is a simple LED-illuminated self-lock switch button. It’s just like a basic switch button, but it lights up color(red/yellow/green/blue/white) when pressed down, which gives you visual feedback. These little buttons can be used with micro: bit to realize various fun interactive projects, such as switch, backlight keyboard, music player panel, and recording control panel.
Note: The module comes with self-lock function. When the button is pressed down, the module outputs High, and the LED lights up. When being pressed again, the module outputs Low and the LED turns off.
Gravity: LED Switch
Connection Diagram
  • Internal LED turns On when the button is pressed down
  • Operating Voltage: +3.3-5V (3.3V is recommended)
  • Output: digital
  • Connector: PH2.0-3P
  • Dimension: 27×26.5mm
  • Colors Available: red, yellow, green, blue, white
  • Gravity: LED Switch x1
  • Digital Sensor Connector x1
    Halloween trick or treat automata with Voice Recognition module
    Projects Halloween trick or treat automata with Voice Recognition module
    RoniBandini
    Oct 16, 2023
