Gravity: LED Button for Arduino / micro:bit (Green)
$4.50
SKU: DFR0785-G
  • $4.40 3+ items
  • $4.30 5+ items
  • $4.10 10+ items
LED switch button with transparent cap lights up in various colors when pressed. Compatible with micro:bit, operates at 3.3-5V, and outputs digital signals.
This is a simple LED-illuminated switch button with a transparent cap. It’s just like a basic switch button, but it lights up color(red/ yellow/ green/ blue/ white) when pressed down, which gives you visual feedback. These little buttons can be used with micro:bit to realize various fun interactive projects!
Note: When pressed down, the module outputs High, and the LED lights up. When released, the module outputs Low and the LED turns off.
Gravity: LED Button
  • Internal LED turns On when the button is pressed down.
  • Operating Voltage: +3.3-5V (3.3V is recommended)
  • Output: digital
  • Connector: PH2.0-3P
  • Dimension: 27×26.5mm/1.06×1.04”
  • Colors Available: red, yellow, green, blue, white
  • Gravity: LED Button - Green x1
  • Digital Sensor Connector x1
  • Out Of Stock
