Gravity: Digital 360° Tilt Sensor for Arduino
$2.50
SKU: DFR0830
  • $2.40 3+ items
  • $2.35 5+ items
  • $2.30 10+ items
A digital tilt sensor detects 360° inclination using a metal ball. It is compatible with 3.3/5V, supports graphical programming, and is safer than mercury switches.
This sensor contains a metal ball that moves along its special internal structure on the effect of gravitation force so as to make a connection or disconnection. Therefore, it can be used as a simple tilt switch. With digital input, this sensor can be used with an Arduino expansion board to realize various fun interactive works, meanwhile, safer than mercury tilt switch.
Compared with the traditional steel ball tilt switch that can only achieve single-direction tilt detection, this product adopts a cylindrical design to allow inclination detection in 360° directions.
Gravity: Digital 360° Tilt Sensor Connection Diagram
Connection Diagram
Note: The top appearance of the 360° tilt switch varies between flat and concave designs in different product batches. Regardless of the design, the functionality and performance of the product remain unaffected.
  • 3.3 / 5V compatible
  • 360° inclination detection
  • Sensitive trigger
  • Support graphical programming like Mind+
  • Teaching experiment - Tilt detection
  • DIY Toy
  • Working Voltage: 3.3~5V
  • Communication: Digital
  • Connector: Gravity
  • Tilt Switch Angle: 45°±10°
  • Module Size: 22*30mm / 0.87*1.18 inches
  • Gravity: Digital 360° Tilt Sensor x1
  • Digital cable PH2.0-DuPont 3P x1
    Roy.WW Dec 14, 2025
    Arrived in good time but I haven't used it yet
